Display VLACP statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
You can enable sequence numbers for each VLACPDU to assist in monitoring performance. The switch counts mismatched PDU sequence numbers to determine packet loss information. By default, sequence numbers are enabled.
You can use the show commands from Privileged EXEC mode but must enter Global Configuration mode to enable or disable the sequence numbers.
Determine if sequence numbers are enabled, and then view port statistics. Port numbering may differ depending on your product and configuration.
Switch:1(config)#show vlacp
Vlacp Global Information
SystemId: 32:11:9f:20:00:00
Vlacp: enable
Vlacp Sequence Number: enable
Switch:1(config)#show interfaces gigabitEthernet statistics vlacp
Port Stats Vlacp
PORT TX RX SEQNUM
NUM VLACPDU VLACPDU MISMATCH
8/1 106058 105554 0
12/11 15 12 0
12/23 0 0 0
Use the data in the following table to use the commands in this procedure.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Job Aid
The following table describes fields in the output for the show interfaces gigabitEthernet statistics vlacp command.
Field |
Description |
PORT NUM |
Shows the slot and port number. |
TX VLACPDU |
Shows the number of VLACPDUs transmitted on the port. |
RX VLACPDU |
Shows the number of valid VLACPDUs received on the port. |
SEQNUM MISMATCH |
Shows the number of mismatched VLACPDUs in terms of received sequence numbers on the port. |
