Use the following procedure to display the configured IKEv2 profiles.
Switch:1#show ike v2-profile test
                                  IKE2 Profile
                                 Hash               Encrypt                  Encrypt       Exchange
Name                             Algo               Algo                     Key Length    Mode
test                             sha256                aesCbc                   256        main
                                  IKE2 Profile
                                 DH                           Integrity                  Lifetime
Name                             Group                        Algorithm                  seconds
test                             modp2048                     sha256                     180
The following table defines parameters for the show ike v-2profile command.
| Variable | Value |
| WORD<1–32> | Specifies the name of the policy. |
Job aid
The following table describes the fields in the output for the show ike v2–profile command.
| Parameter | Description |
| Name | Specifies the name of the IKEv2 profile. |
| Hash Algo | Specifies the hash authorization algorithm. The supported values are MD5, SHA1, and SHA256. |
| Encrypt Algo | Specifies the crytographic algorithm. The supported values are DES, 3DES, and AES. |
| Encrypt Key Length | Specifies the length of the encryption key. The supported values are 128, 192, and 256. |
| DH Group | Specifies the Diffe-Hellman (DH) group. The supported values are modp768, modp024, and modp048. |
| Integrity Algorithm | Specifies IKE SA integrity algorithms supported in IKEv2. |
| Exchange Mode | Specifies the IKE mode. The supported mods are main mode and aggressive mode. |
| Lifetime seconds | Specifies the lifetime value in seconds. The value ranges from 0 to 4294967295 seconds. |
