This procedure only applies to 5520 Series and VSP 4900 Series.
During the device bootup, if an older version of a CPLD module is detected, the system displays a log message to upgrade the CPLD module image.
The following is an example of the log message:
1 2020-01-17T13:08:16.630Z VSP-4900-12MXU-12XE CP1 - 0x0026050d - 00000000 GlobalRouter SW INFO cpu CPLD/FPGA module is running older version. Recommeded to upgrade using command cpld-install.
You can also use show sys-info cpld command to check the current version of the CPLD module on the device.
Upgrade the software on the switch to the latest build.
The cpld-install command compares the image version of the modules with the current version on the device:
If the versions are the same, the command exits.
If the current version is an earlier version, you must update the image version of the specific module.
The device automatically restarts after sucessful installation of the specific module.
Update CPLD for port module.
Switch:1>cpld-install port /intflash/1.1.8_sd_portpld.tgz image file md5 checksum passed Current port CPLD version is 0x1108, 1.1.08 Do you want to continue with cpld update? (y/n) ? y WARNING: Upgrading FPGA requires writing to a device WARNING: It will take about a minute or so to complete. WARNING: DO NOT TURN POWER OFF OR MAKE ANY HARDWARE CHANGES ONCE YOU START THIS OPERATION. FPGA upgrade completed successfully System is going for powercycle now... 1 2019-12-13T14:55:55.577+05:30 VSP-4900-24S CP1 - 0x0026050c - 00000000 GlobalRouter SW INFO port CPLD update completed successfully. CP1 [12/13/19 14:55:56.000] LifeCycle: INFO: Stopping all processes Switch:1>CP1 [12/13/19 14:56:01.000] LifeCycle: INFO: Process slamon.sh (pid:20748) stopping with signal 9 1 2019-12-13T14:56:01.225+05:30 VSP-4900-24S CP1 - 0x0000c5f9 - 00000000 GlobalRouter HW INFO Link Down(1/14). Port is disabled 1 2019-12-13T14:56:01.226+05:30 VSP-4900-24S CP1 - 0x00004726 - 00000000 GlobalRouter SNMP INFO SPBM detected adj DOWN on Port1/14, neighbor 489b.d59d.6884 (VSP-4900-12MXU-12XE) 1 2019-12-13T14:56:01.226+05:30 VSP-4900-24S CP1 - 0x00000033 - 00000000 GlobalRouter SW ERROR dpmSendMulti: LtrSend Failed: Status=9 1 2019-12-13T14:56:01.226+05:30 VSP-4900-24S CP1 - 0x000e05dc - 00000000 GlobalRouter HAL ERROR dpmCosqProfileApply: request ltrSend FAILED 1 2019-12-13T14:56:01.229+05:30 VSP-4900-24S CP1 - 0x0000c5f9 - 00000000 GlobalRouter HW INFO Link Down(1/24). Port is disabled 1 2019-12-13T14:56:01.233+05:30 VSP-4900-24S CP1 - 0x00010756 - 0040000b.3 PERSISTENT SET GlobalRouter HW WARNING Module VSP4900-24S in slot 1 is non-operational 1 2019-12-13T14:56:01.267+05:30 VSP-4900-24S CP1 - 0x00000033 - 00000000 GlobalRouter SW ERROR dpmSendMulti: LtrSend Failed: Status=9 1 2019-12-13T14:56:01.267+05:30 VSP-4900-24S CP1 - 0x000e05dc - 00000000 GlobalRouter HAL ERROR dpmSendMacAddrDelMsg: request ltrSend FAILED 1 2019-12-13T14:56:01.267+05:30 VSP-4900-24S CP1 - 0x00100665 - 00000000 GlobalRouter SW WARNING dpmDeleteMacAddress: failed for Mac = 02:78:84:ff:ff:ff, Mgid = 4052 1 2019-12-13T14:56:01.271+05:30 VSP-4900-24S CP1 - 0x000646fa - 00000000 GlobalRouter MLT INFO IST DOWN, status vector: 0x60000000001800 1 2019-12-13T14:56:01.271+05:30 VSP-4900-24S CP1 - 0x000646da - 01900004 DYNAMIC SET GlobalRouter MLT WARNING SMLT IST Link is DOWN /IST Slave CP1 [12/13/19 14:56:04.000] LifeCycle: INFO: Stopped all processes CP1 [12/13/19 14:56:04.000] LifeCycle: INFO: All processes have stopped CP1 [12/13/19 14:56:04.000] LifeCycle: INFO: Setting shutdown countdown to 300 seconds CP1 [12/13/19 14:56:04.000] LifeCycle: INFO: Flushing buffers ... OK CP1 [12/13/19 14:56:04.000] LifeCycle: INFO: Restarting module CP1 [12/13/19 14:56:05.000] LifeCycle: INFO: Powercycling the system! Using device type 1 (FPGA) RECONFIGURE command enabled Lock file name is /tmp/FPGA_lock FPGA RECONFIGURE operation started. FPGA RECONFIGURE operation SUCCEEDED.
The following table defines parameters for the cpld-install command .
The following table applies to 5520 Series.
Variable |
Value |
| app |
Updates the APP module. |
| boot |
Updates the BOOT module. |
| main |
Updates the main CPLD module. |
| port |
Updates the Port module. |
| WORD<1-99> |
Specifies the image filename. Note: This parameter
is optional. If you do not specify the filename, the command
checks the .tgz file for the image from the running VOSS filesystem.
The following table applies to VSP 4900 Series.
Variable |
Value |
| cpu |
Updates the CPU module. |
| fpga |
Updates the FPGA module. |
| port |
| vim |
Updates the VIM module. |
| WORD<1-99> |
Specifies the image filename. Note: This parameter is optional. If you do not specify the
filename, the command checks the .tgz file for the image from
