Use the show vlan members command to display VLAN port data. The syntax for this command is as follows.
show vlan members <1-4059> [port {slot/port[/sub-port][-slot/port[/sub-port]][,...]} ]
The following table shows the field descriptions for this command.
| Field | Description |
| VLAN ID | Indicates the VLAN ID. |
| PORT MEMBER | Indicates the set of ports that are members (static or dynamic) of this VLAN. |
| ACTIVE MEMBER | Indicates the set of ports that are currently active in this VLAN. Active ports include all static and dynamic ports that meet the VLAN policy. |
| STATIC MEMBER | Indicates the set of ports that are static members of this VLAN. A static member of a VLAN is always active and never ages. |
| NOT_ALLOW MEMBER | Indicates the set of ports that cannot become members of this VLAN. |
| VLAN PORT NUM | Indicates the VLAN port number for the passive OSPF interface. |
