Configure host routes when the switch resides in a network that uses routing protocols other than OSPF. A host route is a more-specific route and is used even if it is higher cost than a network route.
Enable OSPF globally.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
You can specify which hosts directly connect to the router and the metrics and types of service to advertise for the hosts.
Use a host route to create a custom route to a specific host to control network traffic.
 - Click OSPF.
 - Click the Hosts tab.
 - To insert a new host, click Insert.
 - In the IP Address box , type the area IP address of the new host.
 - In the Metric box, type the metric to advertise.
 - Click Insert.
 - Click Apply.
Hosts field descriptions
Use the data in the following table to use the Hosts tab.
 Name  |
 Description  |
 IpAddress  |
 Specifies the IP address of the host that represents a point of attachment in a TCP/IP internetwork.  |
 TOS  |
 Specifies the type of service of the route.  |
 Metric  |
 Specifies the metric advertised to other areas. The value indicates the distance from the OSPF router to a network in the range.  |
 AreaID  |
 Specifies the area where the host is found. By default, the area that submits the OSPF interface is in 0.0.0.0.  |
