This procedure does not apply to VSP 8600 Series.
You must enable RADSec globally and at the RADIUS server level in order for RADSec to be enabled for a RADIUS server.
The following table defines parameters for the radius server host command.
| Variable | Value |
| WORD<0-46> |
Specifies the IPv4 address or the IPv6 address of the RADIUS server. |
| used-by |
Specifies how the server functions. Configures the server for one of the following:
| secure-enable |
Enables RADSec on the RADIUS server. |
