display the configured key details for given key name.
display the digital certificate for the given certificate index or list all the certificate details from the local store if the certificate index is not specified.
display the CA details for given trustpoint CA name or list all the CA details from the local store if the CA name is not specified.
 - Click Certificate.
 - Click the Certificate tab.
Certificate field descriptions
Use the data in the following table to use the Certificate tab.
 Name  |
 Description  |
 Type  |
 Specifies the certificate type.  |
 VersionNumber  |
 Specifies the version number of the certificate for the subject as issued by the Certificate Authority.  |
 SerialNumber  |
 Specifies the serial number of the certificate for the subject as issued by the Certificate Authority.  |
 IssuerName  |
 Specifies the name of the issuer of the certificate for the subject as issued by the Certificate Authority.  |
 ValidStartPeriod  |
 Specifies the start date of the validation period of the certificate for the subject as issued by the Certificate Authority.  |
 ValidEndPeriod  |
 Specifies the last date of the validation period of the certificate for the subject as issued by the Certificate Authority.  |
 CertificateSignatureAlgorithm  |
 Specifies the algorithm used for the signature of the issuer on the certificate for the subject as issued by the Certificate Authority.  |
 CertificateSignature  |
 Specifies the signature of the issuer on the certificate for the subject as issued by the Certificate Authority.  |
 Subject  |
 Specifies the details of the subject on its certificate as issued by Certificate Authority.  |
 SubjectPublicKeyAlgorithm  |
 Specifies the algorithm used to generate the public key of the subject for the certificate issued by the Certificate Authority.  |
 SubjectPublicKey  |
 Specifies the public key of the subject used for the Certificate Signing Request.  |
 HasBasicConstraint  |
 Specifies whether the certificate contains any basic certificate constraint or not.  |
 HasKeyUsage  |
 Specifies whether the certificate contains basic key usage constraint or not.  |
 IsCa  |
 Specifies whether the certificate is a ca certificate or not.  |
 KeyUsage  |
 Specifies the purpose of the key used in the certificate. It is
represented in the form of bits as follows:
 Status  |
 Specifies the status of the certificate.  |
 Installed  |
 Specifies whether the certificate is installed or not.  |
 CdpUrl  |
 Specifies the CDP URL present in the Digital Certificate Extensions field.  |
 OcspUrl  |
 Specifies the OCSP URL present in the Digital Certificate AIA field.  |
 ExtendedKeyUsage  |
 Indicates the purpose for which the key is used in addition to or in place of the basic purposes indicated in the key-usage field of the certificate.  |
