Perform this procedure to enable MAC move protection on virtual interswitch trunk (vIST).
Enable MAC move protection on vIST:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#sys control virtual-ist mac-move-protection
Switch:1>show sys control
System Control Settings
tcp-timestamp : enable
tcp-keepalive-time : 60
tcp-keepalive-interval : 10
tcp-keepalive-probes : 5
mac-move-protection : on
The following table defines parameters for the sys control virtual-ist command.
Variable |
Value |
mac-move-protection |
Enable MAC move protection on vIST. The default value is disabled. |
