Use the following procedure to set the trust factor associated with a port for DAI . By default, the trust factor is set to untrusted.
For ports that are part of an MLT, DAI must be configured using the MLT configuration mode.
You must enable DHCP Snooping globally.
 - Click ARP Inspection.
 - Click the ARP Inspection-port tab.
 - In the row for the port, double-click the IfTrusted field, and select trusted or untrusted to set DAI.
 - Click Apply.
ARP Inspection-port Field Descriptions
Use the data in the following table to use the ARP Inspection-port tab.
 Name  |
 Description  |
 Port  |
 Specifies the port on the switch.  |
 IfTrusted  |
 Specifies the trust factor for DAI on the specific port. By default, it is set as untrusted.  |
