The following section describes a simple configuration example to configure IP Source Guard (IPSG) on a port.
When you enable IPSG on a port, filters are installed for the IPv4 or IPv6 addresses that are already learned on that port.
Enable DHCP Snooping globally on the switch and verify the configuration.
enable
configure terminal
ip dhcp-snooping enable
show ip dhcp-snooping
Enable DHCP Snooping and Dynamic ARP Inspection on the VLAN that the port is a member of.
enable
configure terminal
interface vlan <1–4059>
show ip dhcp-snooping vlan <1-4059>
ip arp-inspection enable
show ip arp-inspection vlan <1-4059>
show ip dhcp-snooping interface gigabitEthernet [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
show ip arp-inspection interface gigabitEthernet [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
Configure IPSG on a port and verify the configuration.
Enable and verify IPSG on a port for IPv4 addresses:
ip source verify enable
show ip source verify interface gigabitethernet [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
Enable and verify IPSG on a port for IPv6 addresses:
ipv6 source-guard enable
ipv6 source-guard [max-allowed-addr <2-10>]
The default value is 4. To reset the value to default, IPSG must first be disabled on the interface.
show ipv6 source-guard interface gigabitEthernet [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
The following example describes how to enable IPSG on port 4/5 which is a member of VLAN 10, for IPv4 or IPv6 addresses.
Switch:1>en Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#
Enable DHCP Snooping globally and verify the configuration.
Switch:1(config)#ip dhcp-snooping enable
Switch:1(config)#show ip dhcp-snooping
                           Dhcp Snooping General Info
        Dhcp Snooping                  : Enabled
Enable DHCP Snooping and Dynamic ARP Inspection on a VLAN that the port is a member of.Switch:1(config)#interface vlan 10
Switch:1(config-if)#show ip dhcp-snooping vlan 10
                            Dhcp Snooping Vlan Info
VLAN       VRF
ID         NAME            ENABLE
10         GlobalRouter    true
All 1 out of 1 Total Num of Dhcp Snooping entries displayed
Switch:1(config-if)#ip arp-inspection enable
Switch:1(config-if)#show ip arp-inspection vlan 10
                            Arp Inspection Vlan Info
VLAN       VRF
ID         NAME            ENABLE
All 1 out of 1 Total Num of Arp Inspection entries displayed
Verify that the port is DHCP Snooping and Dynamic ARP Inspection untrusted.
Switch:1(config-if)#show ip dhcp-snooping interface gigabitEthernet 4/5
                          Dhcp Snooping Interface Info
PORT       PORT            TRUNK
NUM        CLASS           ID
4/5        UNTRUSTED       none
Switch:1(config-if)#show ip arp-inspection interface gigabitEthernet 4/5
                            Arp Inspection Port Info
PORT       PORT            TRUNK
NUM        CLASS           ID
4/5        UNTRUSTED       none
Enable IPSG on port 4/5 for IPv4 addresses, and verify the configuration. This port is a member of VLAN 10.
Switch:1(config-if)#ip source verify enable
Switch:1(config-if)#show ip source verify interface gigabitethernet 4/5
                             Source Guard Port Info
PORT
NUM        ENABLE
4/5        true
All 1 out of 1 Total Num of Ip Source Guard entries displayed
Enable IPSG on port 4/1 for IPv6 addresses, and verify the configuration. This port is a member of VLAN 10.
Switch:1(config-if)#ipv6 source-guard enable
Switch:1(config-if)#ipv6 source-guard max-allowed-addr 10
Switch:1(config-if)#show ipv6 source-guard interface gigabitEthernet 4/1
Slot/Port  Source Guard  Number of  IPv6  Address
             Mode        address allowed  overflow count
4/1          Enabled           10          0
