Use LACP parameters to manage switch ports and their port memberships to form link aggregation groups (LAG). Link Aggregation Control Protocol (LACP) can dynamically add or remove LAG ports, depending on their availability and states.
LACP Global field descriptions
Use the data in the following table to use the LACP Global tab.
| Name | Description |
| Enable | Enables or disables LACP globally. |
| SystemPriority | Configures the system priority for all LACP enabled aggregators and ports. The default value is 32768. |
| FastPeriodicTime | Configures the number of milliseconds between periodic transmissions that use short timeouts. Sets this value to all LACP-enabled ports. The range is 200–20000. The default value is 1000. |
| FastPeriodicTimeOper | Displays the operating value of the fast periodic timer on the port. The default value is 1000. |
| SlowPeriodicTime | Configures the number of milliseconds between periodic transmissions that use long timeouts. All LACP enabled ports get the same value from this setting. The range is 10000–30000. The default value is 30000. |
| SlowPeriodicTimeOper | Displays the operating value of the slow periodic timer on the port. The default value is 30000. |
| AggrWaitTime | Configures the number of milliseconds to delay aggregation to allow multiple links to aggregate simultaneously. The range is 200–2000. The default value is 2000. |
| AggrWaitTimeOper | Displays the operating value of the aggregate wait timer on the port. The default value is 2000. |
| TimeoutScale | Configures the value used to calculate timeout time from the periodic time. All LACP-enabled ports get the same value from this setting. The range is 2–10. The default value is 3. |
| TimeoutScaleOper | Displays the operating value of the timeout scale on the port. The default value is 3. |
| SysId | Specifies the LACP system ID. The default value is f8:73:a2:00:90:00. |
| SmltSysId | Specifies the LACP system ID for Split MultiLink Trunking (SMLT). |
