This procedure does not apply to VSP 8600 Series.
Use this task to configure static routes for the management VLAN.
 - Expand Mgmt Instance.
 - Select Mgmt.
 - Select the Ipv6StaticRoute tab.
 - Select Insert.
 - For the Instance, select vlan.
 - Type the destination IPv6 address and prefix length.
 - Type the next hop IPv6 address.
 - Type a metric value.
 - Select Insert.
Ipv6StaticRoute Field Descriptions
Use the data in the following table to use the Ipv6StaticRoute tab.
 Name  |
 Description  |
 Instance  |
 Specifies the Management Instance.  |
 DestAddr  |
 Specifies the destination IP address.  |
 DestPrefixLen  |
 Specifies the destination prefix length.  |
 NextHop  |
 Specifies the next hop address for the static route. Use an IP address in the same subnet as the management VLAN IP address.  |
 IntfName  |
 Specifies the Management Instance interface name for the route entry.  |
 Metric  |
 Specifies the static route cost. The default is 200. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100.  |
 State  |
 Shows if the route is active or inactive.  |
