View RSMLT edge support information to verify the RSMLT peer MAC/IP address-pair in its local configuration file and restore the configuration if the peer does not restore it after a simultaneous restart of both RSMLT-peer systems.
- Select RSMLT.
- Select the Edge Peers tab.
Edge Peers field descriptions
Use the data in the following table to use the Edge Peers tab fields.
| Name | Description |
| VlanId | Specifies the VLAN ID of the chosen VLAN. |
| PeerIpAddress | Specifies the peer IP address. |
| PeerMacAddress | Specifies the peer MAC address. |
| PeerVrfId | Identifies the Peer VRF. |
| PeerVrfName | Specifies the Peer VRF name. |
