SNMP Trap not Received
Perform the following procedure to troubleshoot issues in which an SNMP trap is not received.
In the following example, BPDU guard is enabled on port 1/8, BPDU packets are received, port 1/8 is disabled, and the TimerCount is incrementing, but no SNMP trap is ever received.
Switch:1>enable
Switch:1#show spanning-tree bpduguard 1/8
Bpdu Guard
Port PORT PORT TIMER BPDUGUARD
NUM MLTID ADMIN_STATE OPER_STATE TIMEOUT COUNT ADMIN_STATE
1/8 Down Down 120 0 Disabled
The following table defines parameters for the show spanning-tree command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
The following table defines parameters for the snmp-server host command.
Variable |
Value |
filter WORD<1-32> |
Specifies a filter profile name. |
host WORD<1-256> |
Specifies the IPv4 or IPv6 host address |
inform [timeout <1-2147483647>] |
Specifies the notify type. The optional timeout parameter configures the timeout value, which specifies the time to wait for a reply before resending the inform message. Time is specified in centiseconds |
noAuthNoPriv|authNoPriv|authPriv WORD<1-32> |
Specifies the security level. |
port <1-65535> |
Specifies the port number that will be set as the destination port at the UDP level in the trap packet. |
retries <0-255> |
Specifies the number of packets to be sent if no reply is received. |
