Use FTP or SFTP to transfer the OVA image to the /var/lib/insight/packages/ directory on the switch.
Perform the following procedure to configure the package information to be used by the virtual service.
- Select Virtual Service.
- Select the Application tab.
- Select Insert.
- In the Name field, enter the virtual service name.
- Next to the PackageName field, select the ellipsis, select the package to install, and then select Ok.
- Select Insert.
Application Field Descriptions
Use data in the following table to use the Application tab.
Name |
Description |
Name |
Specifies the name of the virtual service. |
PackageName |
Specifies the name and location of the package. |
InstallResult |
Shows the status of the virtual service installation. |
InstallStage |
Shows the stages of a package installation. |
