Use the following procedure to configure IS-IS global parameters. SPBM uses IS-IS to discover network topology, build shortest path trees between network nodes, and communicate network information in the control plane.
 - Click IS-IS.
 - From the Globals tab, configure the global IS-IS parameters.
 - Click Apply.
Use the data in the following table to use the Globals tab.
                                 Name  |
                                 Description  |
                                 AdminState  |
                                 Specifies the global status of IS-IS on the switch: on or off. The default is off.  |
                                 LevelType  |
                                 Sets the router type globally:
 The default value is level1.  |
                                 SystemId  |
                                 Specifies the IS-IS system ID for the switch. Valid value is a 6–byte value in the format <xxxx.xxxx.xxxx>. Important:
                            After you have configured the SPBM nickname and enabled IS-IS, if you require a change of the system ID, you must also change the nickname. However, for naming convention purposes or configuration purposes, you may not want to change the nickname. To maintain the same nickname with a different system ID, see Job aid.  |
                                 MaxLspGenInt  |
                                 Specifies the maximum interval, in seconds, between generated LSPs by this Intermediate system. The value must be greater than any value configured for RxmtLspInt. The default value is 900 seconds.  |
                                 CsnpInt  |
                                 Specifies the Complete Sequence Number Packet (CSNP) interval in seconds. This is a system level parameter that applies for L1 CSNP generation on all interfaces. The default value is 10.  |
                                 RxmtLspInt  |
                                 Specifies the minimum time between retransmission of an LSP. This defines how fast the switch resends the same LSP. This is a system level parameter that applies for L1 retransmission of LSPs. The default value is 5 seconds.  |
                                 PSNPInterval  |
                                 Specifies the Partial Sequence Number Packet (PSNP) interval in seconds. This is a system level parameter that applies for L1 PSNP generation on all interfaces. The default value is 2.  |
                                 SpfDelay  |
                                 Specifies the SPF delay in milliseconds. This value is used to pace successive SPF runs. The timer prevents two SPF runs from being scheduled very closely. The default value is 100 milliseconds.  |
                                 HostName  |
                                 Specifies a name for the system. This may be used as the host name for dynamic host name exchange in accordance with RFC 2763. By default, the system name comes from the host name configured at the system level.  |
                                 IpSourceAddress  |
                                 Specifies IP source address for SPBM IP shortcuts.  |
                                 Ipv6SourceAddressType  |
                                 Click ipv6 to use IPv6 addresses.  |
                                 Ipv6SourceAddress  |
                                 Specifies IPv6 source address for SPBM IP shortcuts.  |
                                 IpTunnelSourceAddress  |
                                 Specifies the IS-IS IP tunnel source address.  |
                                 IpTunnelVrf  |
                                 Specifies the VRF name associated with the IP tunnel.  |
                                 MgmtIpAddr  |
                                 Specifies the DvR management IP address for this node, in the DvR domain.  |
                                 BackboneEnable  |
                                 Select to enable this node to join the DvR backbone so that it can receive redistributed DvR host routes from all DvR Controllers in the network.  |
                                 FanMember  |
                                 Specifies whether the node is a member of the Fabric Area Network (FAN) .  |
                                 DynamicallyLearnedArea  |
                                 For FAN members, specifies the IS-IS area that is dynamically learned from the neighbor‘s Hello PDU if the node does not have the IS-IS manual area configured.  |
                                 TcpAdjustMssEnable Note:
                            Exception: Only supported on XA1400 Series.  |
                                 Adjusts the TCP maximum segment size (MSS) to improve the throughput for the TCP session over a Fabric Extend (FE) adjacency. By default, this functionality is enabled and auto-derived.  |
                                 TcpAdjustMssStatus Note:
                                 Displays the activation status of the MSS adjustment functionality. The MSS adjustment functionality only activates when at least one FE tunnel with a maximum transmission unit (MTU) greater than or equal to 1500 is configured.  |
                                 TcpAdjustMssType Note:
                                 Displays if the MSS adjustment value is manually configured or auto-derived.  |
                                 TcpAdjustMssValue Note:
                                 Configures the MSS adjustment value.  |
