Use the show sys power global command to view a summary of the power redundancy settings.
The syntax for this command is as follows.
The output varies according to platform. The following example shows sample command output for one hardware platform.
Switch:1#show sys power global
              slot 1     : critical
              slot 2     : critical
              slot 3     : high
              slot 4     : high
              slot 5     : high
              slot 6     : high
              slot 7     : high
              slot 8     : high
              slot SF1   : critical
              slot SF2   : critical
              slot SF3   : critical
