Use this procedure to view the ingress policer statistics. The system displays individual policer statistics for specific ports to manage network performance.
This command is not available on all hardware platforms.
Switch:1# show interfaces gigabitethernet statistics policer 1/3
                                  QoS Ingress Port Policer Stats
PORT     TOTAL                 TOTAL                 YELLOW                RED
NUM      PKTS                  BYTES                 BYTES                 BYTES
1/3      420                   31628                 0                     0
Use the data in the following table to use the show interfaces gigabitethernet statistics policer command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
