View information about Ethernet errors to display information about the types of Ethernet errors sent and received by a specific MLT or all MLTs.
Important
The IMAC columns refer to internal MAC address errors.
Switch:1#show mlt error main 40
                               Mlt Ethernet Error
MLT  ALIGN   FCS     IMAC    IMAC    CARRIER FRAMES  SQETEST DEFER
ID   ERROR   ERROR   TRNSMIT RECEIVE SENSE   TOOLONG ERROR   TRNSMSS
40    0       0       0       0       0       0       0       0
Variable definitions
Use the data in the following table to use the show mlt error main command.
| Variable | Value |
| <1-512> | Specifies the MLT ID. The value ranges from 1–512. |
