Use the following procedure to display the configured IKE Phase 1 for version 1 and 2 security associations (SA).
Switch:1(config)#show ike sa version v1
IKE V1 Phase 1 Security Association
Policy Addr Initiator/
Name Type Local Address Remote Address Responder
ikepsk IPv4 192.0.2.5 198.51.100.15 Initiator
DPD Hash Encrypt DH Lifetime
Name Timeout Algo Algo Group seconds Status
ikepsk 300 sha aesCbc modp2048 3600 active
Switch:1(config)#show ike sa version v2
IKE V2 Phase 1 Security Association
v2policy IPv4 203.0.113.6 198.51.100.20 Responder
DPD Hash Encrypt Integrity DH Lifetime
Name Timeout Algo Algo Algo Group seconds Status
v2policy 300 sha256 aesCbc modp2048 86400 active
Variable Definition
The following table defines parameters for the show ike sa command.
Variable |
Value |
sa |
Specifies the IKE security association identifier. |
version v1 WORD<1-32> laddr WORD<1-256> raddr WORD<1-256> |
Specifies the local IPv4 or IPv6 address for IKE Phase 1, version 1 SA. |
version v2 WORD<1-32> laddr WORD<1-256> raddr WORD<1-256> |
Specifies the local IPv4 or IPv6 address for IKE Phase 1, version 2 SA. |
Job aid
The following table describes the fields in the output for the show ike profile command.
Parameter |
Description |
Policy Name |
Specifies the name of the IKE Phase 1 policy. |
Addr Type |
Specifies whether the IP address is an IPv4 or IPv6 address. |
Local Address |
Specifies the local IPv4 or IPv6 address. |
Remote Address |
Specifies the remote IPv4 or IPv6 address. |
Name |
Specifies the name of the IKE Phase 1 profile. |
DPD Timeout |
Specifies the Dead-peer detection timeout in seconds. The supported value ranges from 1 to 4294967295 seconds. |
Hash Algo |
Specifies the hash authorization algorithm. The supported values are MD5, SHA1, and SHA256. |
Encrypt Algo |
Specifies the crytographic algorithm. The supported values are DES, 3DES, and AES. |
DH Group |
Specifies the Diffe-Hellman (DH) group. The supported values are MOD768, MOD1024, and MOD2048. |
Lifetime seconds |
Specifies the lifetime value in seconds. The value ranges from 0 to 4294967295 seconds. |
Status |
Specifies the status of the security association. |
