Configure UDP protocols to determine which UDP broadcasts are forwarded.
Configure a UDP protocol and confirm your configuration.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip forward-protocol udp 53 DNS
Switch:1(config)#show ip forward-protocol udp
Udp Protocol Tbl - GlobalRouter
UDP_PORT PROTOCOL_NAME
37 Time Service
49 TACACS Service
53 DNS
69 TFTP
137 NetBIOS NameSrv
138 NetBIOS DataSrv
Variable definitions
Use the data in the following table to use the ip forward-protocol udp command.
Variable |
Value |
<1-65535> WORD<1-15> |
Creates a new UDP protocol. <1-65535> WORD<1-15> is the UDP protocol name as a string. Use the no operator to delete a UDP protocol no ip forward-protocol udp <1-65535>. |
portfwd |
Displays portfwd information. |
portfwdlist |
Displays port forward list information. |
vrf WORD<0-16> |
Specifies the name of the VRF. |
vrfids WORD<0-512> |
Specifies the ID of the VRF. |
