Assign an IP address to a VLAN to enable routing on the VLAN.
If you configure the SLA Mon agent address under an IP interface or VLAN, you must remove the SLA Mon address before you can remove the IP address or VLAN.
- Click VLANs.
- In the Basic tab, select the VLAN for which you are configuring an IP address.
- Click IP.
- Click Insert.
- Configure the required parameters.
- Click Insert.
IP Address field descriptions
Use the data in the following table to use the IP Address tab.
Name |
Description |
Interface |
Shows the interface to which this entry applies. |
Ip Address |
Specifies the IP address to associate with the VLAN. |
Net Mask |
Specifies the subnet mask associated with the IP address of this entry. The value of the mask is an IP address with all the network bits configured to 1 and all the hosts bits configured to 0. |
BcastAddrFormat |
Shows the IP broadcast address format on this interface. |
ReasmMaxSize |
Shows the size of the largest IP datagram which this entity can reassemble from incoming IP fragmented datagrams received on this interface. |
VlanId |
BrouterPort |
Indicates whether this entry corresponds to a brouter port, as oppose to a routable VLAN. |
MacOffset |
Specifies the MAC offset value. Routable VLANS are assigned MAC addresses arbitrarily or by offset. Their MAC addresses are:
If you enter the MAC offset, the lowest 12 bits are 0xA00 plus the offset. If not, they are arbitrary. |
VrfId |
Associates the VLAN or brouter port with a VRF. VRF ID 0 is reserved for the administrative VRF. |
