View information about IGMP groups to see the current group operation on the switch.
View IGMP group information:
Switch:1>enable
Switch:1#show ip igmp group group 232.0.0.0
                           Igmp Group - GlobalRouter
GRPADDR         INPORT          MEMBER          EXPIRATION TYPE
232.0.0.0       V1015-1/2       200.0.15.53     258        Dynamic
1 out of 271 group Receivers displayed
Total number of unique groups 271
The following table defines parameters for the show ip igmp group command.
 Variable  |
 Value  |
 count  |
 Displays the number of entries in the IGMP group.  |
 group <A.B.C.D>  |
 Specifies the address of the IGMP group.  |
 member-subnet {default| <A.B.C.D>}]  |
 Specifies the IP address and mask of the IGMP member.  |
 vrf WORD<1–16>  |
 Specifies the VRF name.  |
 vrfids WORD<0–512>  |
 Specifies the VRF ID.  |
The following table defines parameters for the show ip igmp group group command.
 Variable  |
 Value  |
 detail [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}|vlan <1-4059>|vrfWORD <1–16>|vrfidsWORD <0–255>]  |
 Use the detail parameter to show IGMPv3–specific data. For data related to a specific interface use the following:
 tracked-members  |
 Use the tracked-members parameter to view all the tracked members for a specific group.  |
 vrf WORD<1–16>  |
The following table defines parameters for the show ip igmp group group <A.B.C.D> tracked-members command.
 Variable  |
 Value  |
 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Specifies the port list.  |
 source-subnet <A.B.C.D/X>  |
 Specifies the source IP address and the subnet mask.  |
 vlan <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 vrf WORD<1–16>  |
