Perform this procedure if the client cannot reach the DHCP server.
- Check that the DHCP
relay agent in the network switch is correctly configured.
server configuration is correct.
 - Check for routing issues.
The routing in the network may not be configured so that DHCP request
and reply packets are propagated. You can use ping and traceroute.
pools are correctly configured.
 - If the client cannot
reach the server because the link is down, enable auto-negotiation
on the link.
