Use the following procedure to create accounts for different access levels in enhanced secure mode. You must be the administrator to configure the different access levels.
- You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
Create an account at the auditor level for jsmith:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#password create-user auditor jsmith Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password create-user command.
| Variable | Value |
| {auditor|operator|privilege|security} | Specifies the access level for the user. |
| WORD<1–255> | Specifies the user name. |
