Use the following procedure to configure the minimum required SPBM and IS-IS parameters using the auto-nni command to have the node create an IS-IS interface, attach the interface to an SPBM instance, and then enable IS-IS on the port interface.
This procedure is only for the port interface. The auto-nni command is not supported on the MLT interface and the Fabric Extend Logical Interface.
The auto-nni command provides a quick and simple way to configure the IS-IS interface. You can use the auto-nni command instead of the following existing IS-IS commands on the physical (port) interface:
isis
isis spbm instance
isis enable
The existing commands are still available and you have the option to use the new command or the three existing commands. If you need to modify any of the default parameters under isis or isis spbm instance , use isis and isis spbm instance constructs even if you created the interface with the auto-nni command.
enable
configure terminal
spbm
router isis
spbm <1–100>
spbm <1–100> b-vid {<vlan-id [-vlan-id][,...]} [primary <1-4059>]
spbm <1–100> nick-name <x.xx.xx>
Although it is not strictly required for SPBM operation, you should change the IS-IS system ID from the default B-MAC value to a recognizable address to easily identify a switch (Log on to IS-IS Router configuration mode and use the system-id <xxxx.xxxx.xxxx> command). This helps to recognize source and destination addresses for troubleshooting purposes.
manual-area <xx.xxxx.xxxx...xxxx>
exit
vlan create <2-4059> type spbm-bvlan
interface {GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}| mlt <1–512> }
auto-nni
exit
router isis enable
show isis spbm
show isis
show isis interface
Switch> enable
Switch# configure terminal
Switch(config)# spbm
Switch(config)# router isis
Switch(config-isis)# spbm 1
Switch(config-isis)# spbm 1 b–vid 10,20 primary 10
Switch(config-isis)# spbm 1 nick-name 1.11.16
Switch(config-isis)# manual-area c0.2000.000.00
Switch(config-isis)# exit
Switch(config)# interface GigabitEthernet 1/21
Switch(config-if)# auto-nni
Switch(config-if)# exit
Switch(config)# vlan create 10 type spbm-vlan
Switch(config)# vlan create 20 type spbm-vlan
Switch(config)# router isis enable
Switch(config)# show isis spbm
Switch:1(config)#show isis spbm
ISIS SPBM Info
SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW STP-MULTI
INSTANCE VLAN NAME TRAP HOMING
1 4051-4052 4051 disable disable disable enable disable enable
ISIS SPBM SMLT Info
SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID
INSTANCE
1 primary 00:00:00:00:00:00
Total Num of SPBM instances: 1
ISIS General Info
AdminState : enabled
RouterType : Level 1
System ID : 0014.c7e1.33df
Max LSP Gen Interval : 900
Metric : wide
Overload-on-startup : 20
Overload : false
Csnp Interval : 10
PSNP Interval : 2
Rxmt LSP Interval : 5
spf-delay : 100
Router Name : Switch1
ip source-address : 41.41.41.100
ipv6 source-address : 41:0:0:0:0:0:0:100
ip tunnel source-address : 11.11.12.11
Tunnel vrf : spboip
ONA Port : 1/15
ip tunnel mtu : 1950
Num of Interfaces : 2
Num of Area Addresses : 1
inband-mgmt-ip :
backbone : disabled
Dynamically Learned Area : 00.0000.0000
FAN Member : No
The ONA Port : 1/15
parameter in the preceding example is applicable only to the VSP 4450
Series.
Switch(config)# show isis interface
Switch# show isis interface
ISIS Interfaces
IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1-METRIC
Mlt2 pt-pt Level 1 UP UP 1 1 10
Port1/21 pt-pt Level 1 UP UP 1 1 10
