View the RSTP status for a port to display the RSTP-related status information for a selected port.
View the RSTP status for a port:
                             RSTP Port Status
                          (Port Priority Vector)
Port Number                   : 1/2
Port Designated Root          : 80:00:00:24:7f:9f:60:00
Port Designated Cost          : 0
Port Designated Bridge        : 80:00:00:24:7f:9f:60:00
Port Designated Port          : 80:c1
         Variable definitions
Use the data in the following table to use optional parameters with the show spanning-tree rstp port status command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
