Use the show qos cosq-stats cpu-port command to display the statistics of the forwarded packets and bytes, and the dropped packets and bytes, for the traffic sent toward the CP. The queue assignment is based on the protocol types, not on the internal COS value. These statistics are useful for debugging purposes.
The syntax for this command is as follows:
The first column of the show output can display either protocol type or show queue number depending on your hardware platform.
The following example shows output from the show qos cosq-stats cpu-port command.
Switch:1#show qos cosq-stats cpu-port
QOS CoS Queue Cpu Port Stats Table
CoS Out Packets Out Bytes Drop Packets Drop Bytes
0 0 0 0 0
1 0 0 0 0
2 0 0 0 0
3 0 0 0 0
4 0 0 0 0
5 0 0 0 0
6 414 35714 0 0
7 0 0 0 0
8 561 41738 0 0
9 28740 1969460 0 0
10 12005 2006662 0 0
11 0 0 0 0
12 0 0 0 0
13 0 0 0 0
14 7280 495040 0 0
15 0 0 0 0
Command output can vary across hardware models.
Protocol Accepted Packets Accepted Bytes Drop Packets Drop Bytes
vrrp 0 0 0 0
vlacp 0 0 0 0
lacp 0 0 0 0
cfm 0 0 0 0
vrrp_v6 0 0 0 0
ist_ctl 0 0 0 0
radius 0 0 0 0
ntp 0 0 0 0
icmpv4 0 0 0 0
slpp 0 0 0 0
bpdu 0 0 0 0
tdp 39996 2559744 0 0
eap 0 0 0 0
lldp 8066 1233184 0 0
nd_mc_v6 0 0 0 0
nd_uc_v6 0 0 0 0
rlogin 0 0 0 0
frag_uc_v6 0 0 0 0
isis 0 0 0 0
ospf_mc 8401 783178 0 0
dhcp 0 0 0 0
pim_mc 0 0 0 0
arp_request 3 204 0 0
arp_reply 0 0 0 0
rarp_request 0 0 0 0
rarp_reply 0 0 0 0
icmpv4_bc 0 0 0 0
ospfv6_mc 0 0 0 0
ftp 0 0 0 0
tftp 0 0 0 0
snmp 0 0 0 0
telnet 0 0 0 0
ssh 0 0 0 0
rsh 0 0 0 0
http 0 0 0 0
dns 0 0 0 0
icmp_mc_v6 0 0 0 0
icmp_uc_v6 0 0 0 0
ipmc_data 0 0 0 0
bgp 0 0 0 0
igmp 0 0 0 0
mld 0 0 0 0
pim_uc 0 0 0 0
ospf_uc 0 0 0 0
ospf_v6_uc 0 0 0 0
hop_by_hop 0 0 0 0
rip_v1 0 0 0 0
rip_v2 0 0 0 0
rip_v6 0 0 0 0
mac_learning 0 0 0 0
internal 1 0 0 0 0
data_exception 131 13386 0 0
ttl_exception 0 0 0 0
frag_mc_v6 0 0 0 0
internal 2 0 0 0 0
ipfix 0 0 0 0
Switch:1#
