When you enable the rlogin flag, you must configure an access policy to specify the user name of who can access the switch. For more information about the access policy commands, see Access Policies for Services.
Rlogin is only supported on VSP 8600 Series.
Enable the remote access service to provide multiple methods of remote access.
File Transfer Protocol (FTP), Trivial File Transfer Protocol (TFTP) and Telnet server support both IPv4 and IPv6 addresses, with no difference in functionality or configuration.
Enable the access service for Telnet:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#boot config flags telnetd
The following table defines parameters for the boot config flags command.
Variable |
Value |
ftpd |
Enables the File Transfer Protocol remote-access service type. Use the no operator to remove this configuration. To configure this option to the default value, use the default operator with the command. |
rlogind Note:
Exception: only supported on VSP 8600 Series. |
Enables the rlogin remote-access service type. Use the no operator to remove this configuration. To configure this option to the default value, use the default operator with the command. |
spbm-config-mode |
Enables you to configure SPB and IS-IS, but you cannot configure PIM and IGMP either globally or on an interface. Use the no operator so that you can configure PIM and IGMP. The boot flag is enabled by default. To set this flag to the default value, use the default operator with the command. |
sshd |
Enables the Secure Shell remote-access service type. Use the no operator to remove this configuration. To configure this option to the default value, use the default operator with the command. |
telnetd |
Enables the Telnet remote-access service type. Use the no operator to remove this configuration. To configure this option to the default value, use the default operator with the command. |
tftpd |
Enables the Trivial File Transfer Protocol remote-access service type. Use the no operator to remove this configuration. To configure this option to the default value, use the default operator with the command. |
