- You must configure a RADIUS server before you can enable RADIUS accounting.
Enable Remote Access Dial-in User Services (RADIUS) accounting to log all of the activity of each remote user in a session on the centralized RADIUS accounting server.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# radius accounting enable
Switch:1(config)# radius accounting include-cli-commands
The following table defines parameters for the radius accounting command.
| Variable | Value |
| enable | Enable RADIUS globally. |
| include-cli-commands | Include CLI commands in RADIUS accounting updates. |
| attribute-value <192–240> | Specify the integer value of the CLI commands attribute. |
