Use this procedure to view a summary of the DvR configuration on a DvR Controller or a DvR Leaf.
View the information on a DvR Controller:
Switch:1#show dvr
DVR Summary Info
Domain ID : 5
Domain ISID : 16678219
Backbone ISID : 16678216
Role : Controller
My SYS ID : 00:bb:00:00:81:21
Operational State : Up
GW MAC : 00:00:5e:00:01:25
InjectDefaultRouteDisable(GRT) : Enabled
View the information on a DvR Leaf:
Switch2:1#show dvr
DVR Summary Info
Domain ID : 5
Role : Leaf
My SYS ID : 00:bb:00:00:71:23
Inband Mgmt Clip IP : 72.54.44.1
Virtual Ist local address : 51.51.51.1
Virtual Ist local subnet mask : 255.255.255.0
Virtual Ist peer address : 51.51.51.2
Virtual Ist cluster-id : 255
Virtual Ist ISID : 16677226
Job aid
Use the data in the following table to use the show dvr command output.
On a Controller:
Field |
Descriptions |
Domain ID |
Specifies the domain ID of the DvR domain to which the Controller belongs. |
Domain I-SID |
Specifies the DvR domain I-SID. The range is 16678217 to 16678727. |
Backbone I-SID |
Specifies the backbone I-SID. The value is 16678216. |
Role |
Specifies the role of the node in the DvR domain, namely Controller. |
My SYS ID |
Specifies the MAC address of the Controller. |
Operational State |
Specifies the operational state of the Controller. |
GW MAC |
Specifies the gateway MAC address. |
InjectDefaultRouteDisable |
Specifies whether injection of default routes is disabled on the Controller. The default is disabled. |
On a Leaf node:
Field |
Descriptions |
Domain ID |
Specifies the domain ID of the DvR domain to which the Leaf node belongs. |
Domain I-SID |
Role |
Specifies the role of the node in the DvR domain, namely Leaf. |
My SYS ID |
Specifies the MAC address of the Leaf node. |
Operational State |
Specifies the operational state of the Leaf node. |
GW MAC |
Inband Mgmt Clip IP |
Specifies the in-band management CLIP IP address. |
Virtual Ist local address |
Specifies the local IP address of the node, if vIST is configured. |
Virtual Ist local subnet mask |
Specifies the subnet mask of the local IP address of the node, if vIST is configured. |
Virtual Ist peer address |
Specifies the IP address of the peer node, in the vIST pair. |
Virtual Ist cluster-id |
Specifies the cluster ID if vIST is configured. |
Virtual Ist ISID |
Specifies the I-SID if vIST is configured. |
