Use this procedure to display IP Multicast over Fabric Connect summary information.
Display IP Multicast over Fabric Connect global configuration information:
Switch:1>enable
Switch:1#show isis spbm multicast
multicast : enable
fwd-cache-timeout(seconds) : 210
Switch:1#show isis spb-mcast-summary
SPB multicast - Summary
SCOPE SOURCE GROUP DATA LSP HOST
I-SID ADDRESS ADDRESS I-SID BVID FRAG NAME
GRT 192.0.2.102 233.252.0.1 16000001 63 0x0 DIST5A
Switch:1#show ip mroute route
Mroute Route - GlobalRouter
GROUP SOURCE SRCMASK UPSTREAM_NBR IF EXPIR PROT
233.252.0.1 0.0.0.0 0.0.0.0 0.0.0.0 V3 30 spb-access
233.252.0.1 198.51.100.99 255.255.255.0 0.0.0.0 - 0 spb-network
Total 4
Variable definitions
The following table defines parameters for the show isis spb-mcast-summary command.
Variable |
Value |
count |
Displays the total number of SPB multicast entries. |
host-name WORD<0–255> |
Displays the IP Multicast over Fabric Connect summary information for a specific host-name. |
lspid <xxx.xxx.xxx.xx-xx> |
Displays the IP Multicast over Fabric Connect summary information for the specified LSP ID that you enter in xxx.xxx.xxx.xx-xx — 8 byte format. |
The following table defines parameters for the show ip mroute route command.
Variable |
Value |
vrf WORD<1–32> |
Specifies a VRF. |
vrfids WORD<0–255> |
Specifies the VRF ID |
Job aid
The following table describes the fields in the output for the show isis spbm multicast command.
Parameter |
Description |
multicast |
Specifies if multicast is enabled. |
fwd-cache-timeout (seconds) |
Specifies the forward cache timeout value in seconds. |
The following table describes the fields in the output for the show isis spb-mcast-summary command.
Parameter |
Description |
SCOPE I-SID |
Indicates the I-SID that specifies the multicast streams when the scope is either the Layer 3 VSN or the Layer 2 VSN or any combination. |
SOURCE ADDRESS |
Indicates the IP multicast source address that maps to the I-SID. |
GROUP ADDRESS |
Indicates the IP multicast group address that maps to the I-SID. |
DATA I-SID |
Indicates the data I-SID for the IP multicast route, which includes the source IP address, group IP address, and the local VLAN that the stream is received on (S,G,V tuple). SPBM uses the data I-SID to create the multicast tree. |
BVID |
Indicates the ID of the SPBM backbone VLAN (B-VLAN) on which the multicast stream forwards in the SPBM cloud. |
LSP FRAG |
Indicates the fragment number of the LSP ID. |
HOST-NAME |
Indicates the host name of the router. |
The following table describes the fields in the output for the show ip mroute route command.
Parameter |
Description |
GROUP |
Indicates the IP multicast group for this multicast route. |
SOURCE |
Indicates the network address that, when combined with the corresponding value of SRCMASK, identifies the sources for this multicast route. |
SRCMASK |
Indicates the network mask that, when combined with the corresponding value of SOURCE, identifies the sources for this multicast route. |
UPSTREAM_NBR |
Indicates the address of the upstream neighbor from which IP datagrams from these sources to this multicast address are received. The field displays the value of 0.0.0.0 if the (S,G) source is local or if the RP for this the (*,G) group is an address on this router. |
IF |
Indicates the value of ifindex for the interface that receives IP datagrams sent by these sources to this multicast address. A value of 0 in a (*,G) route indicates that datagrams are not subject to an incoming interface check, but datagrams can be received on any interface. |
EXPIR |
Indicates the minimum amount of time remaining before this entry ages out. The value 0 indicates that the entry is not subject to aging. Note:
The value you configure for fwd-cache-timeout applies only to the locally learned sender; it does not apply to SMLT synchronized sender records. |
PROT |
Indicates the multicast protocol through which the switch learned this route. The spb-access and spb-network values indicate the stream learned when IP Multicast over Fabric Connect is configured on the VLAN. The spb-access value indicates that it was learned on the access. The spb-network value indicates it was learned over the SPBM cloud. |
