Perform this procedure to downgrade the switch from the current trusted version to a previous release.
Important
In VOSS 4.2 and later, the encryption modules are included in the image file. Therefore, the load-encryption command and the software add-module command is present but no longer applicable to the current release. You do not require a CLI command to add or load the encryption module. Use the software add-module command only if you downgrade to a release earlier than VOSS 4.2.
Important
MACsec connectivity association (CA) configurations fail during downgrade. If you plan to downgrade MACsec to an earlier version, delete the MACsec CA entries, perform the downgrade, and then reconfigure the MACsec CA entries. This applies to both 2AN and 4AN modes.
Ensure that you have a previous version installed.
The image file name is switch dependent. See Release Notes for VOSS for information about file names.
The following table defines parameters for the software command.
Variable |
Value |
activate WORD<1-99> |
Specifies the name of the software release image. |
add WORD<1-99> |
Specifies the path and version of the compressed software release archive file. |
remove WORD<1-99> |
