Use the show ip mroute hw-resource-usage command to display information about the hardware resource use of an IP multicast route.
This command is not supported on a node configured as the DvR Leaf within a DvR domain.
The syntax for this command is as follows:
show ip mroute hw-resource-usage [vrf WORD <0–32>] [vrfids WORD <0–255>]
| Field | Description |
| EGRESS REC IN-USE | Displays the number of egress records traversing the switch. |
| INGRESS REC IN-USE | Displays the number of ingress records (source or group) traversing the switch. |
| EGRESS THRESHOLD | Displays the configured egress threshold level (0–32767). A notification message is sent if this value is exceeded. The default is 0. |
| INGRESS THRESHOLD | Displays the configured ingress threshold level (0–32767). A notification message is sent if this value is exceeded. The default is 0. |
| LOG MSG ONLY | Displays whether only log notification messages are sent after the threshold level is exceeded. The default is false (disabled). |
| SEND TRAP ONLY | Displays whether only trap notification messages are sent after the threshold level is exceeded. The default is false (disabled). |
| SENT TRAP AND LOG | Displays whether both trap and log notification messages are sent after the threshold level is exceeded. The default is false (disabled). |
