Configure an IPv6 redistribute entry to announce IPv6 routes of a certain source protocol type into the BGP domain, for example, static, OSPF, IS-IS, RIPng, or direct routes. Use a route policy to control the redistribution of routes.
When a route map with attributes set to origin and local-pref is applied to the BGP redistribute command, the attributes are not applied to the redistributed routes.
                                        If required, a route policy exists.
Specify a route policy to govern redistribution by using the following command:
Switch:1(router-bgp)#redistribute ipv6–direct route-map policy2
The following table defines parameters for the redistribute <ipv6-direct|ipv6-static|ospfv3|ipv6–isis|ripng>command.
| Variable | Value |
| enable | Enables the BGP route redistribution instance. The default value is none. To configure this option to the default value, use default operator with the command. To disable this option, use no operator with the command. |
| metric<0–65535> | Configures the metric to apply to redistributed routes. The default value is 0. To configure this option to the default value, use default operator with the command. |
| route-map <Word 0-64> | Configures the route policy to apply to redistributed routes. The default value is none. To configure this option to the default value, use default operator with the command. |
Job Aid
Use the data in the following table to know how route policies are used for BGP from IPv6 perspective.
| REDISTRIBUTE | ACCEPT | ANNOUNCE | |||||
| IPv6 Direct | IPv6 Static | OSPFv3 | IPv6 IS-IS | RIPng | BGP | BGP | |
| MATCH | |||||||
| as-path | Yes | Yes | |||||
| community | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| community-exact | Yes | Yes | |||||
| extcommunity | Yes | Yes | |||||
| interface | |||||||
| local-preference | |||||||
| metric | Yes | Yes | |||||
| network | Yes | Yes | |||||
| next-hop | Yes | Yes | |||||
| protocol | |||||||
| route-source | Yes | ||||||
| route-type | Yes | Yes | |||||
| tag | |||||||
| vrf | |||||||
| vrfids | |||||||
| SET | |||||||
| as-path-mode | Yes | Yes | |||||
| automatic-tag | |||||||
| community-mode | Yes | Yes | |||||
| injectlist | Yes | Yes | Yes | Yes | Yes | ||
| ip-preference | |||||||
| local-preference | Yes | Yes | |||||
| mask | |||||||
| metric | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| metric-type | |||||||
| metric-type-internal | |||||||
| nssa-pbit | |||||||
| origin | Yes | ||||||
| origin-egp-as | |||||||
| tag | |||||||
| weight | Yes | ||||||
