View the I-SID forwarding database (FDB).
To view the T-UNI I-SID FDB entries filtered on a port that is part of an MLT, you must mention the MLT ID in the option for the port.
FDB field descriptions
Use the data in the following table to use the FDB tab.
Name |
Description |
IsidId |
Specifies the service interface identifier (I-SID). |
Address |
Specifies the MAC address of the port assigned to the specific I-SID or C-MAC learned on the particular I-SID. |
Status |
Specifies the learning status of the associated MAC. |
Port |
Specifies the port on which the MAC is learned for the specific I-SID. |
PortType |
Specifies whether the MAC is a local or IST-peer or a remote MAC. |
RemoteMacDestAddr |
Specifies the virtual BMAC address or system-ID of the remote destination. |
RemoteMacBVlanId |
Specifies the BVLAN ID on which the remote destination was discovered. |
RemoteMacDestSysName |
Specifies the remote destination system name. |
Cvid |
Specifies the customer VLAN ID of the associated Switched UNI port. |
