Use the following procedure to generate the private and public key pair for the specific cryptography type.
Certificate key-pair field description
Use the data in the following table to use the tab.
 Name  |
 Description  |
 Type  |
 Specifies the cryptography algorithm used to generate the key-pair.  |
 Size  |
 Specifies the size of the key-pair to be generated.  |
 Name  |
 Specifies the name of the key-pair generated for the subject. This name is auto-generated as the combination of key-type and key-size.  |
