Important
Changing route preferences can affect system performance and network accessibility while you perform the procedure. Change a prefix list or a routing protocol before you activate the protocols.
Configure IPv6 route preferences to give preference to routes learned for a specific protocol.
Configure the route preference to RIPng and confirm the configuration is correct.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#ipv6 route preference protocol ripng 10
Switch:1(config)#show ipv6 route preference
IPv6 Route Preference - GlobalRouter
PROTOCOL DEFAULT CONFIG
LOCAL 0 0
STATIC 5 5
SPBM_L1 7 7
OSPFv3_INTRA 20 20
OSPFv3_INTER 25 25
EBGP 45 45
RIPNG 100 100
OSPFv3_E1 120 120
OSPFv3_E2 125 125
IBGP 175 175
Variable definitions
Use the data in the following table to use the ipv6 route preference and the show ipv6 route preference commands.
Variable |
Value |
<0-255> |
Assigns a route preference value. |
ebgp |
Configures the preference for protocol type EBGP. |
ibgp |
Configures the preference for protocol type IBGP. |
ospfv3-extern1 |
Configures the preference for protocol type OSPFv3 external type 1. |
ospfv3-extern2 |
Configures the preference for protocol type OSPFv3 external type 2. |
ospfv3-intra |
Configures the preference for protocol type OSPFv3 intra-area. |
ospfv3-inter |
Configures the preference for protocol type OSPFv3 inter-area. |
ripng |
Configures the preference for protocol type RIPng. |
spbm-level1 |
Configures the preference for protocol type spbm-level1. |
static |
Configures the preference for protocol type static. |
