Use this procedure to switch to another VRF context view when you use the embedded EDM. GlobalRouter is the default view at log in. You can configure both Global Router (GRT) and Virtual Routing and Forwarding (VRF) instances when you launch a VRF context view. You can open only five tabs for each EDM session.
Important
If you log out from the GRT view, the system generates a warning: all tabs close and your session terminates. If you close a VRF view tab, you close only that view.
The Set VRF Context view function is not available to users in a service provider deployment where only a tenant VRF view is assigned.If you use a tenant VRF view, as a best practice, use the applicable EDM plugin with COM to access EDM. COM provides VRF mapping and Role-Based Access Control.
VRF field descriptions
Use the descriptions in the following table to use the VRF tab.
Name |
Description |
Id |
Shows the unique VRF ID. |
Name |
Shows the name of the virtual router. |
ContextName |
Shows the SNMPv3 context name that denotes the VRF context and logically separates the MIB port management. |
