Revoke a License
Revoke a license on the switch if you need to transfer the license to a different switch.
You can permanently remove a license, which allows you to transfer the license to another switch. This should only be done when preparing to return a defective switch for a replacement switch (RMA).
This procedure only applies to 5520 Series.
The revokeLicensePremier or revokeLicenseMacsec parameter invalidates the feature license and generates a revocation certificate, which is the first step to releasing the license entitlement back to the license entitlement manager (LEM). The revocation certificate is contained in a file where the first part of the file name is the switch serial number and the file extension is .rvk.
- Select Chassis.
- Select the System tab.
- In ActionGroup1, select either revokeLicensePremier or revokeLicenseMacsec.
- Select Apply.
- In ActionGroup1, select saveRuntimeConfig.
- Select Apply.
System Field Descriptions
Use the data in the following table to use the System tab.
Name |
Description |
sysDescr |
Shows the system assigned name and the software version. |
sysUpTime |
Shows the elapsed time since the system last started. |
sysContact |
Configures the contact information. |
sysName |
Configures the name of this device. |
sysLocation |
Configures the physical location of this device. |
VirtualIpAddr |
Configures the virtual IP address that the primary CPU advertises and stores in the switch configuration file. |
VirtualNetMask |
Configures the net mask of the virtual management IP address. |
VirtualIpv6Addr |
Specifies the virtual IPv6 address. |
VirtualIpv6PrefixLength |
Specifies the length of the virtual IPv6 address prefix (in bits). |
DnsDomainName |
Configures the default domain for querying the DNS server. |
LastChange |
Displays the time since the last configuration change. |
LastVlanChange |
Displays the time since the last VLAN change. |
LastStatisticsReset |
Displays the time since the statistics counters were last reset. |
LastRunTimeConfigSave |
Displays the last run-time configuration saved. |
DefaultRuntimeConfigFileName |
Displays the default Run-time configuration file directory name. |
ConfigFileName |
Specifies the name of a new configuration file. |
ActionGroup1 Note:
Exception: revokeLicensePremier and revokeLicenseMacsec only supported on the 5520 Series. |
Can be one of the following actions:
LicenseFileName Note:
Exception: only supported on the 5520 Series, VSP 8600 Series, and the XA1400 Series. |
Specifies the name of the license file when copied to the flash. The destination file name must meet the following requirements:
ActionGroup2 |
Specifies the following action: resetlstStatCounters—Resets the IST statistic counters |
ActionGroup3 |
Can be the following action:
ActionGroup4 |
Result |
Displays a message after you click Apply. |
LocatorLED Note:
Exception: only supported on 5520 Series and VSP 4900 Series. |
Configures the system Locator LED on or off. The default is off. |
