This procedure applies to 5520 Series and VSP 7400 Series.
After you configure the advanced-feature-bandwidth-reservation boot flag and reboot with the new configuration, you can use the following procedure to verify that the switch reserved ports for configuring advanced features such as Fabric Extend, SPB, SMLT, vIST, VXLAN Gateway, Fabric RSPAN (Mirror to I-SID), Application Telemetry, or IS-IS Accept Policies.
show sys-info
Switch# show sys-info General Info : SysDescr : Switch1 (w.x.y.z) BoxType: Switch1 SysName : Switch1 . . . Advanced Feature Bandwidth Reservation: -------------------------------------------------------------------------------- Reservation Mode : low Port Usage Info : 1/31 and 1/32 are not available to use
