View your configuration to review the information and ensure it is correct.
Variable definitions
Use the data in the following table to use the show filter acl and show filter acl config commands.
Variable |
Value |
<ace-id> |
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch. |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
