Feature |
Product |
Release introduced |
For configuration details, see VOSS User Guide. |
Multicast route (mroute) statistics for IPv4 and IPv6 |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 5.1 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 5.1 |
VSP 8400 Series |
VOSS 5.1 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
Not Supported |
The multicast route statistics feature provides statistics for multicast streams through the switch. Using the Command Line Interface (CLI), Simple Network Management Protocol (SNMP) or Enterprise Device Manager (EDM), you can track the number of senders sending multicast streams to a particular group address. You can also obtain a count of the packets or bytes being received for a particular multicast group address and the average size of the frames. Multicast route statistics are supported for both IPv4 and IPv6 group addresses.
Determining the route statistics is especially useful when debugging a multicast network and also when administering the network.
When you enable or clear IP multicast route statistics on the Controller node of a DvR domain, the configuration is automatically pushed to the Leaf nodes within the domain.
For more information on DvR, see Distributed Virtual Routing (DvR) Fundamentals.
