Display Endpoint Tracking binding information.
Display all VLAN:I-SID binding information on the switch for Endpoint Tracking.
- Select Endpoint Tracking.
- Select the Binding tab.
Binding Field Descriptions
Use the data in the following table to use the Binding tab.
| Name | Description |
IfIndex |
Specifies the interface index of the selected port or MLT. |
MacAddress |
Specifies the MAC address that corresponds to the VLAN:I-SID binding. |
Status |
Specifies the Endpoint Tracking data binding status as follows:
VlanId |
Specifies the VLAN ID. |
Isid |
Specifies the I-SID value, either provided by the RADIUS server, or calculated using the VLAN ID plus the configured I-SID offset value. |
IsidSource |
Specifies whether the I-SID value is provided by the RADIUS server (radius), or calculated using the VLAN ID plus the configured endpoint-tracking offset value (autoconfig). |
Timeout |
Specifies the timeout period that is applied to the MAC in the bindings table when the MAC is aged out. If the MAC is in timeout state (there is no response from the RADIUS server), the timeout triggers immediately with a 15 minute period. Otherwise, the default timeout is one day, and triggers the moment the MAC ages out from the VLAN/ISID bridge forwarding database (FDB) table. The default timeout of one day can be overridden by the RADIUS server if the Session-Timeout attribute is configured and returned. |
TimeRemaining |
Specifies the time remaining until the Endpoint Tracking data binding entry expires. |
