The following section describes common procedures that you use while you configure and monitor the switch operations using the Command Line Interface (CLI).
Unless otherwise stated, to perform the procedures in this section, you must log on to the Privileged EXEC mode in the CLI. For more information about how to use CLI, see CLI procedures.
