View topology message status to view the interconnections between Layer 2 devices in a network.
In the following example, the column “ChassisType” uses a generic name. When you use the show autotopology nmm-table, your switch displays the actual chassis type.
Switch:1(config)#show autotopology nmm-table
                                      Topology Table
Local        Rem
Port     IpAddress       SegmentId MacAddress   ChassisType            BT LS  CS   Port
0/0      192.0.2.81     0x000000  0030ab707a00 ChassisType 1          12 Yes HtBt  0/0
1/1      192.0.2.81     0x000000  0050ea268800 ChassisType 2          12 Yes HtBt  1/50
1/42     192.0.2.81     0x000000  070ab307aa00 ChassisType 3          12 Yes HtBt  1/1
2/1      192.0.2.81     0x000000  0030ab57ab00 ChassisType 4          12 Yes HtBt  1/49
2/2      192.0.2.81     0x000000  0030ab307af0 ChassisType 5          12 Yes HtBt  1/50
2/41     192.0.2.81     0x000000  00e0ba327c00 ChassisType 6          12 Yes HtBt  2/1
2/42/1   192.0.2.81     0x000000  0050eb127400 ChassisType 7          12 Yes HtBt  1/2
When a peer switch is running an older software version that does not include support for SONMP hello messages with channelization information, it can only show the slot/port. It cannot show the sub-port.
Job Aid
The following table describes the column headings in the command output for show autotopology nmm-table.
| Variable | Value |
| Local Port | Specifies the slot and port that received the topology message. |
| IpAddress | Specifies the IP address of the sender of the topology message. |
| SegmentId | Specifies the segment identifier of the segment from which the remote agent sent the topology message. This value is extracted from the message. |
| MacAddress | Specifies the MAC address of the sender of the topology message. |
| ChassisType | Specifies the chassis type of the device that sent the topology message. |
| BT | Specifies the backplane type of the device that sent the topology message. The switch uses a backplane type of 12. |
| LS | Indicates if the sender of the topology message is on the same Ethernet segment as the reporting agent. |
| CS | Specifies the current state of the sender of the topology message. The choices are
| Rem Port | Specifies the slot and port that sent the topology message. |
