The documentation does not include information about how to use RESTCONF clients. This example documents some common tasks using Python.
Configure the RESTCONF server on the switch.
#!/usr/bin/env python
import sys
import json
import requests
from requests import Request, Session
from requests.auth import HTTPBasicAuth
from requests.packages.urllib3.exceptions import InsecureRequestWarning
requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
Host = '192.0.2.1'
TcpPort = ‘8080'
UserName = 'rwa'
PassWord = 'rwa'
LoginUrl = 'https://%s:%s/auth/token' % (Host, TcpPort)QueryUrl = 'https://%s:%s/rest/restconf/data/' % (Host, TcpPort)
vlan = 123
session = Session()
session.verify = False
session.timeout = 5
session.headers.update({ 'Accept': 'application/json',
'Accept-Encoding': 'gzip, deflate, br',
'Connection': 'keep-alive',
'Cache-Control': 'no-cache',
'Pragma': 'no-cache‘, })
The token expires after 24 hours.
body = '{"username": "%s", "password" : "%s" }' % (UserName,PassWord)
response = session.put( LoginUrl, body )
if response.status_code != 200:
print "ERROR: Login failed"
sys.exit(1)
else: session.headers.update({
'X-Auth-Token': response.headers['X-Auth-Token‘]
print "INFO: login passed"
response = session.get( QueryUrl + 'openconfig-vlan:vlans' )
print 'ERROR: can‘t fetch VLANs'
response = session.get( QueryUrl + 'openconfig-vlan:vlans/vlan=%s' % vlan )
print 'INFO: VLAN %s doesn‘t exists' % vlan
else:
print 'INFO: VLAN %s exists' % vlan
inbound_data = json.loads( response.text )
for vlan in inbound_data['openconfig-vlan:vlans' ]['vlan']:
print 'VLAN: %s [%s]' % ( vlan['state']['name'], vlan['vlan-id‘] )
for dataVlan in inbound_data[ dataObject ]['vlan']:
print ''
print 'VLAN: ' + dataVlan['state']['name'] + '[' + dataVlan['vlan-id'] + ']'
interfaces = ' '
if 'members' in dataVlan :
for interface in dataVlan['members']['member ']:
interfaces = interfaces + interface['interface-ref']['state']['interface'] + ','
print interfaces
dataObject = 'openconfig-vlan:vlans‘
data = { "openconfig-vlan:vlan": [
{ "config":
{ "name": "Test-VLAN",
"extreme-mod-oc-vlan:stg-id": 1,
"vlan-id": vlan
response = session.post( QueryUrl + dataObject, json=data )
if response.status_code != 201:
print "ERROR: add VLAN %s failed" % vlan
else:
print "INFO: VLAN %s added " % vlan
dataObject = 'openconfig-vlan:vlans/vlan=%s/config' % vlan
data = { "openconfig-vlan:config":
{ "name": "New-VLAN-Name" }
response = session.patch( QueryUrl + dataObject )
if response.status_code != 204:
print "ERROR: update VLAN %s fails" % vlan
else:
print "INFO: VLAN %s updated" % vlan
dataObject = 'openconfig-vlan:vlans/vlan=%s' % vlan
response = session.delete( QueryUrl + dataObject )
print "ERROR: delete VLAN %s fails" % vlan
else:
print "INFO: VLAN %s deleted" % vlan
