This procedure does not apply to VSP 8600 Series.
Use this task to view the default topology IP address for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Mgmt.
 - Select the TopologyIp tab.
TopologyIp Field Descriptions
Use the data in the following table to use the TopologyIp tab.
 Name  |
 Description  |
                                 AddrType  |
                                 Shows the IP address type for the topology IP.  |
                                 Addr  |
                                 Shows the IP address for the topology IP.  |
                                 InterfaceName  |
                                 Shows the interface name of the identified interface for the topology IP.  |
 InstanceId  |
 Specifies the interface instance for the topology IP.  |
