Configure ACE IP protocol entries to have the filter look for packets of specific protocols.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click IP.
 - Click the Protocol tab.
 - Click Insert.
 - Specify the operation type.
 - In the List box, enter the IP protocol type.
 - Click Insert.
Protocol field descriptions
Use the data in the following table to use the Protocol tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq parameter specifies an operator for a field match condition: equal to.  |
 List  |
 Specifies the IP protocol type. Entries include 0–256, undefined, tcp, udp, ipsecesp, vrrp, and undefined.  |
