Configure ACE destination port entries to have the filter look for packets with a specific destination port.
The ACE exists.
The ACL exists.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click ACE.
- Select the appropriate ACE.
- Click Proto.
- Click the Destination Port tab.
- Click Insert.
- Specify the operator for the destination port.
- Specify the port number or port list to match.
- Click Insert.
Destination Port field descriptions
Use the data in the following table to use the Destination Port tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| Oper | The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits. |
| Port | Specifies the port number. As noted at the bottom of the tab, potential entries include 0–65535, echo, ftpdata, ftpcontrol, ssh, telnet, dns, http, h.323, and undefined. |
| OperMask | Specifies the mask parameter, {0-0xFFFF}. |
